<img src="graemlins/sweat.gif" border="0" alt="[sweat]" />
Both of them are dead players IF you ever need to rebuild (bore) them. Both are thin in the cylinders. I would pass, but I can build my own engines. For you..... GM has a new 383 Crate engine and a short block too. If you can wrench a little....... buy one of the NEW ones and go form there. New 1 piece rear seal set up for the roller cam (you select) never bored.... available at your local dealership (no freight) Just my 5 cents .
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
Deuce Roadster... has a very good point... "NEW" has a future the others dont... Also the newer iron is of a later generation and has more improvements as he mentioned also... If spending that kind of cash go with the new and enjoy it much longer...
Well, concidering the fact that even a stroker engine will run 50,000 on the street very easily if you dont scatter it, I would say either MIGHT be a good choice. It depends on your plans. For the street in the 400-450 HP range I think the will be fine. Try to push 500 or more, and the cylinders will surely split unless grouted. If tall grouted, the streetabliliy becomes seriously limited.
Chris |
I would have to agree with deuce roadster. go with a "new" crate engine
