01 Blazer fan speed problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2011, 02:24 PM
01 blazer
Can only get heater fan to run on high.
Slow and medium are off.
What should I look for first.
Thanks
Bob
Old 02-12-2011, 02:27 PM
LATECH's Avatar
blower resistors are pretty common on those. It is under the dash near the blower motor.It will require a 5.5 millimeter socket to remove it.You could try wiggling the connector first with the power on to see if it starts, that would be a quick indicator of trouble.The connectors on them are Crap and they melt.
Old 02-12-2011, 07:17 PM
Blower moter
Thanks
I'll check it out
Old 02-12-2011, 08:50 PM
On high speed there is a direct connection to 12 volts. On lower speeds it runs through the resistor pack to reduce voltage and lower the fan speed. The resistors heat up when used, and over time they may get hot enough to break. Its usually an easy fix.
Bruce
Old 02-16-2011, 06:30 AM
Fan motor
Probkem found
Wire connector going into the resistor is bad.
Need wire harness end.
Thanks for the info
S10 Blazer 4WD Problem klutchmaster427 Transmission - Rearend 9 10-23-2009 09:39 PM
88 S10 Blazer Trans problem wahamilton87 Transmission - Rearend 4 06-12-2009 06:13 PM
Need Help Locating Speed Sensor on 98 Chevy S10 Blazer. Ghetto Jet Transmission - Rearend 4 05-17-2008 12:09 AM
strange problem with blazer ricksautorestoration Engine 5 01-15-2007 10:02 PM
96 blazer hesitation problem ricksautorestoration Engine 1 11-07-2006 10:02 PM
