01 Blazer fuel pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2011, 02:47 PM
01 Blazer fuel pump
Two months ago I replaced the fuel pump in my son's 01 Blazer.
For the last week or so he has been complaining about hard start problem when cold.
Because of his work schedule I have not been able to check much.
Last night it would not start at the mall so I went down with some gas in a can and found it would start if I put gas into the intake.
i changed the fuel pump Raleigh with another one with the same numbers on it.
my guess is defective new fuel pump but what do I know. I'm a transmission guy.
got pump from pep boys.
Thanks for any help
Bob
Old 05-30-2011, 05:41 AM
willowbilly3's Avatar
Last journal entry: Body mods
Some aftermarket pumps are junk. I have had issues with the Airtex brand before and won't use them now. Can you hear the pump humm when you cycle the key?
Old 05-30-2011, 06:48 AM
fuel pump
No I can't hear the pump.
I didn't see anything wrong with the connector when I disconnected it from the tank so I'm guessing it's the pump.
Bob
Old 05-31-2011, 04:50 PM
fuel pump
Car died at mall Friday night.
Poured Son gas into the intake and it started and stalled.
Picked up my son and friend.
Towed to shop and found no fuel pressure.
Defective fuel pump less than 2 months old.
Bob
Old 06-03-2011, 05:16 AM
fuel pump
replaced fuel pump.
Pump was a carter.
Isn,t carter one of the good manes?
runs good.
Sorry I didn't get back sooner. been busy.
Thanks for the info.
Bob
Old 06-03-2011, 06:14 AM
Three Stooges
Avoid the "Three Stooges". Did Pep Boys replace the pump under their warranty?
Old 06-03-2011, 08:58 PM
fuel pump
Yes
For over $ 200 dollars the better.
Thanks
Bib
95 gmc jimmy fuel pump won't shut off/fuel pump relay garystrosnider Electrical 7 10-28-2010 07:10 AM
96 blazer fuel pump ricksautorestoration Engine 15 06-07-2009 02:16 PM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 8 06-04-2006 11:56 PM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 0 03-18-2006 09:40 PM
