01 Dodge brake problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2008, 11:18 PM
79z28's Avatar
79 Camaro z28
Last journal entry: rear wiring harness off
My ABS/brake lights came on the other day and when it did that my cruise control wouldn't work, so i checked the brake line and fluid level...all were good but just curious what might be causing that cause it's happened before. It's on my 2001 Dodge Ram 1500 Sport with 109k miles. I'm thinking since i drove up to the top of the canyon and back down & used my brakes more than usual instead of putting it into a lower gear that my brake fluid heated up by doing that. The light is off now and the cruise control works again so maybe it's just overuse of the brakes and nothing needs to be done?
Old 06-24-2008, 09:53 AM
79z28's Avatar
79 Camaro z28
Still no input on what's wrong with my truck but the ABS and brake lights came on again yesterday and are still on. I pulled the ABS fuse and it cleared for about 30 miles then the lights came back on. So i figure it's something electrical, maybe a sensor or ABS solenoid. I figure i'll get a code reader or get a Chiltons (if it has the codes in there) since i have no idea what's wrong.
Old 06-24-2008, 10:03 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Are your pads worn? Also, check the sensors at the calipers, they may be crudded up, spray with carb cleaner works. Look on the differential for a sensor lead as well. That sensor should read around 2k ohms. If it shows open or opens with a 'wiggle' test, that could be your problem. Most auto parts stores will run a scan for you for free.
I've also heard of a blown fuse in the tail light circuit or blown bulb causing ABS and cruise control problems. When I blew a tail light on my motor home, the cruise was disabled. Good luck.
Semper Fi
Old 06-24-2008, 10:49 AM
I would suspect one of the speed sensors, both the cruise and abs use those sensors for speed input. You really need to get the abs code before wasting any time and money swapping parts out to correct the issue.
E Brake problem. schapo Suspension - Brakes - Steering 4 04-21-2008 06:03 PM
Ft Disc Brake Problem - '68 Impala GCD1962 Suspension - Brakes - Steering 2 04-25-2007 04:58 AM
Chevy II Front Brake Conversion problem Trevor Horn Suspension - Brakes - Steering 5 04-05-2007 08:10 PM
Major Brake Problem... HELP ME! 98rocket Suspension - Brakes - Steering 8 03-17-2003 05:22 PM
Brake problem NEED HELP 74huggerorange Suspension - Brakes - Steering 7 02-27-2003 06:46 PM
