01 Ford F-250 Tranny issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2013, 06:45 PM
Hey guys! My daily driver is a 2001 Ford F-250 7.3 powerstroke auto 2wd. Recently the transmission started acting up. it was rebuilt about 3 years ago. The reverse sometimes just wont work at all, sometimes it works a little, but it shutters really bad then goes. now it seems like the overdrive isn't working at all. it is shifting really hard and the overdrive light on the shifter is blinking. Any idea whats going on guys? I really need help. This is my transportation to work and I cant afford to rebuild it right now. Any input would be greatly appreciated!! Thanks in advance. Jake
Old 07-18-2013, 10:46 PM
the flashing od light means there are "codes" relating to the trans stored in the pcm access them and they will help diagnose what is wrong
Old 07-20-2013, 02:23 PM
How would I go about accessing them? Is that something they could do at oreillys or autozone?
Old 07-20-2013, 06:03 PM
it would be worth a try, the sophistication of the test equipment has a lot to do with it. codes 0-999 are available by law to any code reader but codes 1000 and up are used buy the factory for advanced diagnosis and other diagnostics systems such as air bags, anti-lock brakes , air suspension etc.
Old 07-21-2013, 01:56 AM
ok. thank you
Old 07-21-2013, 06:16 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Flashing OD lite indicates codes as mentioned here. With codes in system the computer deletes use of OD and raises line pressure (harsh shifts).
These trans historically have slow reverse Engadgement. 3 clutch packs come on at once. The shutter in R indicates a problem. Could be hard seals, loose clearance. There is a method to set the reverse clutch up with tighter clearance. Your builder may not know this method.
Read codes, clear codes, run main line pressure test on all gears. Watch pressure in reverse, should boost up from forward gears
Old 07-21-2013, 04:29 PM
LATECH's Avatar
Trans codes are P0700 and to P0799. Autozone code reader may not give you specific P07XX codes as they are trans codes.
You will need a better scanner .
Fact is stranger than Fiction
ford f-250 montdad Engine 1 03-21-2010 01:25 PM
tranny issues cooling and vaccum nova327 Engine 16 02-03-2010 11:19 PM
driveline issues and tranny question pat63chevy Transmission - Rearend 12 11-26-2007 06:59 PM
tranny issues shane97 Transmission - Rearend 2 02-06-2007 10:01 AM
97 Firebird tranny issues 97FloridaBird Transmission - Rearend 5 12-08-2004 05:32 AM
