'01 Jeep G. Cherokee Fan & Temp Lights
The lights for the fan speed and the heater temp are burning out one by one on my 2001 Jeep Grand Cherokee. Can anyone tell me how I can get into the dash/console to change these lights?
Thanks... George |
Only Need to Replace Bulbs...
I think it is just a matter of age that the bulbs have burned out. I do not thnk that there is a short or anything like that. How do I get into the console area to just swap out the bulbs?
Thanks... George |
disassemble dash
You will have to look around and find all the various screws, clips, nuts, and bolts that hold the dash together. IF your gauges are in a cluster, on the bezel of your cluster, you should find some sheet metal screws that hold it in. Undo the screws and carefully remove the cluster pod from the dash. The bulbs are small and are either push in or twist in with half turn sockets. If your gauges are all in a cluster, then the cluster pod is all that you will need to remove.
Trying to explain where all the screws are would be difficult, but experience tells me there shouldnt be more than half a dozen screws and they would go through the gauge cluster bezel into the dashboard. Usually they are phillips screws and will need a couple of #2 phillips screwdrivers. You will need a short and a long screwdriver most likely, for ease of reaching the screws through the steering wheel and around it. Once you get all the retaining screws out, the pod should come out with out any prying or hammering. |
What about the Fan Control Lights?
Thanks for the information. That makes sense for the gauge lights in the dashboard cluster. That process is similar to removing the gauge cluster in the 2nd generation Trans Ams I am restoring.
The lights that seem to have gone out in my 2001 Jeep Grand Cherokee are the fan speed control light(s). These are located below the radio and in front of the gear selector? How would I get to those lights? Thanks... George |
light on the subject
Most likely your radio is held in by clips that require a couple of U-shaped tools that go into the holes on each side of your radio. You can see them on the facia. This is a new standard way of holding radios in place. These U shaped tools are available at your local auto parts store, for just a coupld dollars. They have a point on each end and just up the shafts from the point you will see a groove all the way around. You insert a U tool in each side of the radio, and push them in til you feel them lock in place. Once this is done you can remove the radio. If you can not reach the lights from through the nicale where the radio was mounted, Im lost.
| Recent Interior posts with photos |
