01 S-10 with V8 conversion, 4L60e does not shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2011, 11:04 PM
What's up? I'm building an '01 S-10 ext. cab originaly w/ a 4.3 L. I have installed a '92 camaro RS 5.0 w/ edelbrock carb backed up to the original 4L60E trans. Mind boggling reading about issues w/ this tranny. No first, second & third ok, no OD . Trans control solenoid's or wiring ? It was working fine before the V 6 blew a head gasket. Removed all ,hopefully, unnessisary fuel injection & O-2 sensor wiring. All but the tach work fine on the panel. Any help on this issue would be greatly appreciated. Short on funds & don't want to waste $ on chasing gremlins. Thank you Hotrod Nation!!!
Old 12-24-2011, 11:17 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The 4L60e requires computer controls to shift and operate correctly. Sounds like you removed computer inputs from engine and voltage power to the transmission.
There is a large ( 1.25 inch diameter) connector on passenger side of the transmission, above the pan rail. Did you remove that?
You may need to check for blown fuses too
Old 12-24-2011, 11:19 PM
pricesgarages's Avatar
with out a ecm the tranny will not work the ecm controls shifts and pressure
only options are use a non computer controlled tranny or a aftermarket transmission control unit
4L60E Shift kit. GMCTRUCKS Transmission - Rearend 8 05-20-2012 04:22 PM
4L60E won't shift out of first BigScott Transmission - Rearend 5 04-15-2011 08:59 PM
4l60e does not shift now Badazz93 Transmission - Rearend 3 05-02-2009 01:05 AM
4l60e no shift jkotila Transmission - Rearend 2 10-01-2007 02:46 PM
4l60e won't shift out of first 50 chevy p/u Transmission - Rearend 6 07-28-2006 09:43 AM
