Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 02 Explorer paint defect
Old 07-22-2012, 09:16 AM
eric302's Avatar
eric302 eric302 is offline
Why be normal?
I am fixing the paint defects on a 02 Explorer (paint bubbling and peeling). Apparently Ford is aware of this cause there is a TSB out on this problem. It appears to be limited to the aluminum body panels, hood and front fenders. The worst part is on the front edge of the hood. I am no stranger to collision work but this is my first time at aluminum panels as most of the work I do is on older cars. I was going to sand the corrision and sand till I get to good metal, wash it good with dawn, wipe it with SPI water based cleaner, SPI epoxy, metal glaze, Seal wth reduced SPI epoxy and base/clear. Do I need to use any kind of special cleaner on the bare aluminum? Thanks in advance.
