02 Honda Accord Key Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2010, 03:55 PM
HerbMarshall420's Avatar
I have never came across this problem before. I thought someone on here might know what is going on.
I have an 02 Honda Accord.
I have a key that works in every way.
I got the working key copied.
The copy works in doors and trunk.
The weird thing is when I put the key in the ignition it turns the car on and
turns the motor, but the motor will not fire.
Any ideas?
Old 08-31-2010, 05:21 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
It probably has an antitheft I would assume. The new key will have to be coded by the dealer or shop with the right scanner software. The launch 431 will do it but who has it?
If your original key is big and kinda puffed up then it has the transducer in it. that is what they use to signal the antitheft system that it is ok to enable fuel and spark so the car will run. If the new one you had cut doesnt have the transducer you can make a windchime out of because it will never start the car. The antenna for the transducer is a ring of wire (coil) that circles the lock cylinder on the steering column it picks up the signal from the key when it is inserted
Old 09-01-2010, 05:57 PM
boatbob2
Key......
Hi,if you have the original key,take it to the dealer,he can replace it. BUT,most dealers want to see the vehicle registration IN YOUR NAME.
Old 09-01-2010, 07:25 PM
LATECH's Avatar
Hee Hee .. yes they do ...boatbob ...yes they do. For obvious reasons LOL
92 accord lx starting problems 406 ss monte Engine 8 03-09-2010 01:52 AM
02' blazer with 4l60e problems lp14255 Transmission - Rearend 15 01-22-2009 09:04 AM
71 ply scamp cranks but dies when key is released Footstomper Electrical 10 09-09-2007 07:55 AM
89 honda accord, headlights wont work...and... Rubberman2003 Electrical 6 02-10-2005 05:26 AM
Problems with the Honda now Ghetto Jet Hotrodders' Lounge 30 01-22-2005 11:19 AM
