02' silverado trailer light wiring scematic help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2013, 02:01 AM
327amc's Avatar
Owner of a broken cart
I need to install a plug to pull a few different trailers.
I have a pig tail hanging off my truck. The wires are
Brown Park Lamps,
Gren LT Backup,
Gren Dk Rt Turn,
Yel Lt Turn,
Wht Grnd,
Blue Lt CHMSL
I need to know where the wires go in the terminal im holding in the photo.
There are 7 labeled terminals. A, B, C, D, E, F, G
This will be the plug that will be permanently attached to the truck.
Thanks in advance.
ALso, what the heck does CHMSL mean?
Old 06-18-2013, 02:08 AM
Old 06-18-2013, 01:07 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
stop
CHMSL = center-high-mounted-stop-lamp
vicrod
Old 06-18-2013, 09:44 PM
327amc's Avatar
vicrod
Dang! I never would have got that.
Old 06-18-2013, 09:46 PM
327amc's Avatar
Thanks for the replys. Problem solved.
Old 06-18-2013, 11:32 PM
327amc's Avatar
I guess I jumped the gun. That wiring may be correct, but I have no way of knowing where to put those colors in my plug because I have a different shaped plug (that can be seen in the original post). This is the 7way GM truck side plug Delphi pa66.
This is what im working with. And this almost solves my problem, except ofcourse, the colors are different in this example.
Old 06-19-2013, 03:47 AM
EOD Guy's Avatar
The plug in the pic looks like a "T" connector? ie.... locate the crossover harness by the tail lights, unplug it and plug in each side of the "T" connector?
Old 06-19-2013, 11:06 AM
327amc's Avatar
LOL thats exactly what I thought when my pops picked up this T connector. I thought, well that probably just plugs right into the factory harness. NOPE! The factory trailer pigtail we have has nothing on it. Its just taped off.
That is the whole problem. I have to wire the PA66 plug into the truck so I can plug the T connector into it. I need to know where the wires go in the PA66 plug.
Old 06-19-2013, 04:07 PM
EOD Guy's Avatar
So to recap.... you have an existing pig tail/harness on the truck, with wires as described in your 1st post. Should be easy to extend those wires directly into the 7 pin connector, doing away with the "T" portion of the new harness. The "T" just makes it plug and play.......since you already have a pig tail the "T" isn't needed.
Old 06-19-2013, 10:03 PM
327amc's Avatar
He wants plug and play.
I know I can hook up the existing wires to a 4 pin blade connector. But he wants what I am asking about.
I have to wire the PA66 plug into the truck so I can plug the T connector into it. I need to know where the 02 silverado wires go in the PA66 plug.
trailer wiring ? lanier ledford Hotrodders' Lounge 2 09-26-2008 07:07 PM
04 silverado trailer brake problem shady4 Electrical 2 05-17-2008 08:57 AM
trailer wiring brian12c Hotrodding Basics 7 09-13-2006 08:32 PM
wiring for trailer crownver Electrical 12 04-16-2006 12:09 AM
92-94 PARKING LIGHT LAMP fit 89 silverado? Echofive Body - Exterior 0 01-11-2006 09:12 PM
