. 028 gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2008, 09:39 PM
. 028 gasket
I am cleaning up an old 4 bolt 350 Chev. I put in a 2102 cam (Edelbrock) and lifters. I am running this engine in an 1989 Chev. 1/2 ton. I bought and installed a Mr Gasket gasket kit and now after reading a whack of info on quench ,I have ordered up .028 head gaskets to reduce the quench. I will get serious this time with the heads off to determine the deck height and the ccs of the 882 heads . From what I measured before, I was at .020 in the hole. These are high compression forged pistons . Not doing my home work has caused me to think (NOT KNOW) that the head gasket is.040 Am I correct in thinking that .060 is too much quench.
Old 06-30-2008, 12:10 AM
SSedan64's Avatar
.048" quench will be much better than .060".
Mr. Gasket Arcuden Engine 12 10-02-2007 05:27 PM
Percy xx carbon exhaust gasket material - passed my first (and second) stress tests lowROLLERchevy Engine 6 02-17-2007 10:29 PM
Beware of one piece oil pan gasket for a Ford 460..... onebadmerc Engine 0 12-30-2006 07:00 PM
Changing pan gasket on 350 chevy rapsag Engine 16 08-04-2005 08:55 AM
Clearance/head gasket questions hlweyl Engine 16 01-31-2004 04:53 AM
