03 Chevy S10 Vaccum line routing from transfer case switch? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2012, 08:48 PM
mike 96 ws6's Avatar
old dog learning new tricks
I'm trying to sort out some burnt / mis-routed vaccum lines on my 03 ZR2. Why does the tranfer case vaccum switch have a 3 line connector. I would think that 1 goes to energize the front axle actuator under the battery - and 1 goes to vaccum source (T off EGR valve on my truck). Where does the 3rd line go?
Also, does someone have a link to a good vaccum diagram for this circuit. I have a Haynes manual and Alldata subscription but neither is much help.
Thanks,
Mike
Old 02-12-2012, 09:09 PM
LATECH's Avatar
The third hose is the vent for the vacuum when switching back to 2wd
Old 02-12-2012, 09:15 PM
Yep, I relized that after I posted. I got it all hooked up right with new lines, connectors and a transfer case vaccum switch.
Thanks!
1884 chevy k10 700r4 or transfer case problems? 84K10PickemUpTruck Transmission - Rearend 3 01-07-2012 08:34 AM
Chevy Transfer Case Speeds JRDModifications Transmission - Rearend 2 05-31-2006 08:09 PM
Vaccum Routing ap0001 Engine 0 03-29-2003 06:00 PM
1999 Chevy Silverado Transfer Case/Transmission? officialfoxracer21 Transmission - Rearend 2 12-15-2002 05:56 PM
76 chevy transfer case purplePeopLEater Transmission - Rearend 5 12-15-2002 11:54 AM
