'03 escape fwd axle nut..
trying to get my son's car alt out.. wow what a mess... getting to all the nuts on the exh manifold ain't fun, so i'm going to pull the axle and go that route... i measured the nut, flat to flat and its 24mm but some web site say 32mm.. any insite on the PITA job. 2003 ford escape V6 fwd automatic.
did i measure it wrong ?? tks bill |
Pull the Axle, and there is a stud for the alt bracket that may need to come out.It will EEK out and EEK back in.But it will fit, I have done it. You will have to "nudge the engine forward" a little.Dont recall nut size.
Taking off the exhaust and all that Is BS. |
alt removal
i got it out....FINALLY !!!!!!!!!!!! as for measuring the nut size i need a class in reading the caliper i used.. was looking at the wrong spot on the slider, thats why i got it wrong... look up stupid and you'll see my picture.. yes droping the exh was not needed, but i did need to pull the alt bracket for more room.. if the alt was a nats butt bigger u'd need to pull the engine..
what a pain.. now tonite to put it back.. woop peeeeee |
stop by an autoparts store and get a new nut..
they are a one time deal |
wheel nut..
wow.. tks, i did not know that.. will do that soon then..
tks for the info.. |
| All times are GMT -6. The time now is 06:00 AM. |
