'03 escape fwd axle nut.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2012, 07:04 AM
delawarebill's Avatar
trying to get my son's car alt out.. wow what a mess... getting to all the nuts on the exh manifold ain't fun, so i'm going to pull the axle and go that route... i measured the nut, flat to flat and its 24mm but some web site say 32mm.. any insite on the PITA job. 2003 ford escape V6 fwd automatic.
did i measure it wrong ??
tks bill
Old 12-20-2012, 04:49 PM
LATECH's Avatar
Pull the Axle, and there is a stud for the alt bracket that may need to come out.It will EEK out and EEK back in.But it will fit, I have done it. You will have to "nudge the engine forward" a little.Dont recall nut size.
Taking off the exhaust and all that Is BS.
Fact is stranger than Fiction
Old 12-21-2012, 08:28 AM
alt removal
i got it out....FINALLY !!!!!!!!!!!! as for measuring the nut size i need a class in reading the caliper i used.. was looking at the wrong spot on the slider, thats why i got it wrong... look up stupid and you'll see my picture.. yes droping the exh was not needed, but i did need to pull the alt bracket for more room.. if the alt was a nats butt bigger u'd need to pull the engine..
what a pain.. now tonite to put it back.. woop peeeeee
Old 12-21-2012, 09:06 AM
gearheadslife's Avatar
MentalMuffinMan
stop by an autoparts store and get a new nut..
they are a one time deal
Old 12-22-2012, 12:30 PM
wheel nut..
wow.. tks, i did not know that.. will do that soon then..
tks for the info..
wear spot in carpet below foot rest Ford Escape Duntov Interior 2 09-03-2010 12:01 PM
not a ford nut or a gm nut either ddwspringer Introduce Yourself 4 07-27-2009 08:05 AM
97 Ford f350 rear axle nut problems. Rubberman2003 Transmission - Rearend 5 03-21-2009 07:21 PM
stupid fwd bowtiebadboy Transmission - Rearend 4 08-08-2005 07:23 PM
FWD wheelie 61bone Suspension - Brakes - Steering 3 05-22-2005 11:48 AM
