03 Ford Ranger 3.0 rough idle ???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2011, 06:32 AM
i have a 2003 ford ranger with a 3.0 113,000 miles engin the truck was put on a scanner n it shows notting just says the truck is running great shows no problems what so ever ...... but the truck sometimes has a rough idle sometimes so bad itll stall .......... i could start it now n it might be perfect for hours but then i could start it now have the rough idle go drive then maybe hour later its gone running perfect but then again it could just stay rough..... cant figure out why ??????????????? does anyone know what it could be ??? or what to try ??? thank you Rob
Old 07-31-2011, 11:15 AM
Wiki Edits: 31
common problem. clean the idle air control. they carbon up.
Old 07-31-2011, 11:28 AM
03 ranger
you mean the Mass Air Flow ? ? ?
Old 07-31-2011, 12:26 PM
Wiki Edits: 31
no, answer is in the reply PM
Old 07-31-2011, 05:30 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Lower intake leaks are pretty common on those. Look at the fuel trims, short term left and right.If one or both is too high (adding over 5%) chances are the intake is sucking air. Clean the IAC first and the throttle body as mentioned here earlier. See how it turns out. Good luck.
The MAF should be cleaned also, be careful with it so as not to break it.
Rough idle, high idle in park, stalls in gear.. Help! ratmaro Engine 18 03-23-2012 05:29 PM
1981 Gm 3.6 V6 Rough Idle And High Idle nomaddaddy Engine 1 11-15-2007 09:49 PM
1983 Ford Ranger won't idle 1957ford General Rodding Tech 3 04-25-2005 08:37 PM
Rough idle crush56 Engine 4 03-08-2005 01:58 PM
rough idle ap0001 Engine 5 04-14-2003 06:15 PM
