'03 GMC wipers won't turn off - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2009, 11:48 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I did a search for wiper issues, and found nothing about wipers that won't shut off. This on an '03 GMC Sierra pickup with 40k miles.
Driving to work this morning, had my wipers on intermitten when they started full time operation. I tried to shut them off, no luck. They will operate on high and low speed, low speed throughout all ranges of intermitten and no shut off, had to pull the fuse.
Any ideas? Thanks!
Semper Fi
Old 01-20-2009, 12:19 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Switch gone bad...thats all I can think of.
Old 01-20-2009, 01:42 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
That's kind of my thought too, I just thought maybe it had lost it's mind and would reset it I disconnected power. Guessing the switch is in the column, I'll track it down, thanks.
Semper Fi
Old 01-20-2009, 08:33 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Got home from work and did the tap tap thing on the drivers wiper base and it started acting right. Guessing if it was the broken solder issue that wouldn't happen, assuming it's moisture in the motor, I see a fix for that to open the motor cover, dry it and seal it. I'll give that a shot.
Just thought you all might want to know the high tech fix.....
Semper Fi
Old 01-20-2009, 08:54 PM
302 Z28's Avatar
The park cam might be getting ready to fail. Pull of the wiper motor cover and give a look see.
Vince
Old 01-20-2009, 09:09 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
I was told about a solder issue in the wiper motor circuit board being the fault, from a former GM mechanic/co-worker. He told me, you just have to pull the wiper motor circuit board, and re-melt a solder joint.
I hope this helps.
Old 01-20-2009, 10:02 PM
302 Z28's Avatar
I hope this helps.
That is true, but that fixes an intermittent issue where the wipers just quit working at the most inopportune time.
Vince
Old 01-20-2009, 10:38 PM
My 2 cents worth
Wiki Edits: 3
Vince
Not to disagree but;
He pulled a 'self soldered' wiper motor circuit board out of his tool box, and it fixed the same identical problem, on that truck, that day at work, and it fixed the problem. I won't get into the tail light problems on this board.
Ask me if I would want to hire him, my answer would be always NO.
Just because, all he had worked at, was at GM dealerships, and he knew nothing about any other brand of Vehicles, other than GM Vehicles.
Old 01-20-2009, 10:57 PM
302 Z28's Avatar
I know what you mean. The TSB I saw referred to the intermittent quit problem and addressed the cold solder joint on the wiper motor board right where the plug solders on. I was experiencing the problem on a 97 Tahoe we had and almost replaced the intermittent control module when I ran across the TSB. I pulled the cover off the wiper motor and with a magnifying glass was able to spot the broken solder joint. A quick touch with a hot iron to remelt the solder and it was fixed, never to return again.
Vince
78 camaro turn signal help hcker2000 Electrical 16 06-15-2007 05:06 PM
turn my engine backup to get the power i had koop Engine 1 05-01-2007 12:04 PM
03 gmc sierra astrops Electrical 4 04-27-2005 08:32 PM
Turn signals won't shut off after turning! 1meancuda Electrical 2 09-01-2004 02:48 PM
17" Wheel Change '03 GMC 68NovaSS Suspension - Brakes - Steering 1 06-26-2003 10:48 PM
