03 nissan sentra heating problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2013, 05:01 PM
327 / 350 hp's Avatar
Hi ,, I am hoping i can get some help with my sons sentra 1,9lt.. He bought it with this problem with little or cold air from the heater. Sometimes it overheats but not boiled over. We replaced the thermostat .. By Google we figured it was the head gasket. Replaced that.. When it is warmed up (guage) the upper rad hose is hot ,,bottom is cool. Rad fans 2 are cutting in and out per normal. We power flushed the core, block and rad today. There is a bleed screw above the thermostat housing sometimes it bubbles other times not.. Anybody thanks Jim
Old 03-03-2013, 05:21 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Are you sure the water is circulating? Maybe the water pump impeller is not turning. I have seen them spin on the pump drive shaft due to cracking,loosening of hubs, fins getting broken off.
Fact is stranger than Fiction
Old 03-04-2013, 12:00 PM
nissan heating problems
Yes other than the belt at fault there can't be much else.. We are pricing a new pump and belt for it for next weekend. I did change the rad hoses to the engine ,, the top rad hose now goes to thermostat housing and he tells me he now has heat to interior and guage stays a tad below half way. Jim
Timing a 2000 Nissan Sentra revone Engine 2 07-06-2012 11:43 AM
Is it possable to change a ring gear on a nissan sentra 1985 fumplet Engine 4 06-22-2006 03:02 PM
NISSAN SENTRA BOOSTER & MASTERCYL. SWAP WAYNE MITCHELL Suspension - Brakes - Steering 1 07-13-2005 11:20 AM
Over heating problems. Mollard Engine 9 01-01-2005 06:15 AM
heating problems monte Engine 2 07-11-2002 07:30 PM
