.030 over 350??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2004, 01:48 PM
Mightymouse's Avatar
Chevy SS
.030 over 350???
i have a .030 over 350 small block chevy with keith black 9.7:1 compression ratio pistons used with 76cc heads and i wuz wondering if anyone could help me build my top end ect.. heads, rocker arms, intake, carb and also i dont know what type of cams to choosed yet either but its going to be a daily driver so i dont want it to be too wild and i want it to run on pump gas plus i want to get around 300-350 horsepower... any suggestions???
Also i want to go with a new set of heads i dont wanna rebuild any stockers
Old 06-17-2004, 06:32 PM
Chevy SS
Old 06-17-2004, 06:44 PM
BOBCRMAN@aol.com's Avatar
Go with an aftermkt S/R type head. Use a mild Hydraulic lifter cam with short duration and high lift. A set of new rocker arms. 1.5 ratio is fine. A Performer type intake and a 600-750 Vac. secondary carb.
Old 06-17-2004, 06:46 PM
Chevy SS
do you think the world product sportsman II or s/r torquer heads would be good?
Old 06-17-2004, 07:08 PM
stepside454's Avatar
Mighty mouse, whats it goin in ? what gear ratio? tranny ?
Old 06-17-2004, 07:10 PM
Chevy SS
its going into a 85 monte carlo i dont know about the gears but the transmission is a 350 with a b&m shift kit
Old 06-17-2004, 07:14 PM
knowing the gear is sort of critical, but if its not an SS its most likely around a 3.08.... if thats the case, are you planning on staying with that gear...or up it to say a 3.42 ?
Part of the reason I ask is cam selection, you can still make good power, but with 3.08s, youll want to stay more conservative.
Old 06-17-2004, 07:15 PM
Chevy SS
yea its not an SS and ide really like to keep the same gearing for now but i mite change it later on so what do u think about cam specs???
also what do u thank a good combination would be beetween heads, rocker arms, intake and carb to get the most power out of it
Old 06-17-2004, 07:35 PM
If it were me Id either use the SportmanIIs or Vortecs(dont forget ,vortec requires a dedicated intake, self aligning rockers & centerbolt valve covers) for heads.
for camshafts(assuming a flat tappet hydrulic) my first choice would be: Schneider racing cams grind # LSP-1H Specs: duration 214/224 @ .050
lift .440/.460 112LSA
or
Speed-Pro # CS1013R specs:
duration 214/224
lift .445/.465 112LSA
For an intake Id use either an Edelbrock Performer or Weiand Action +
For a Carb Id either use a nicley prepped Qjet, or a 570 Holley Street Avenger( would most likely work best with a 1" open spacer), or a 600 CFM carb of your choice( Iprefer Holley over Edelbrock/carters).
Ill assume you plan to put headers & 2.25" exhaust.
you should easily make your 350 HP with that compression, & should be very torky right out of the hole.
oh, by the way, this will be a motor to run within 5500 RPMs.
Old 06-17-2004, 07:36 PM
Chevy SS
Sweet thanks alot!!!
and i thank ill go with the sportsman II heads and what would you say about the rocker arms????
And where can i find these camshafts at???
Old 06-17-2004, 08:21 PM
roller rockers do help, Im not a fan of aluminum rollers for daily drivers though, unless there good quality like Harland sharp, but there pricey. The Comp Pro magnum stainless rockers are bullet prove, not the cheapest, but I say pay now, or wish you did later.
You can find Schneider cams by going to there website( there not the cheapest). I know Northern Automotive carrys Speed-Pro Cams, & very reasonable prices,They also have a website.
Old 06-17-2004, 08:25 PM
Chevy SS
Alright thanks alot!
so will these cams give the engine that rump rump sound or will it be quite?
Old 06-17-2004, 08:31 PM
jlraiders04's Avatar
New Member
Last journal entry: oo
just installed zz383
look at bthe stats nice engine
Old 06-17-2004, 08:33 PM
Mighty, both well be fairly smooth, but lotsa torque, with a 3700 LBS. Monte carlo with 3.08s in a daily driver you want torque, lumpy cams generally dont give a bunch of torque, or vacuum for that matter.
Old 06-17-2004, 08:35 PM
Chevy SS
yea i know... i just like the sound of a lumpy cam :-D it sounds cool but i want whatever will give me the most power how much do them schnider cams usually run i cant find a price for the one ut telling me
Hey thanks alot!! BIG HELP! ill proly have this engine done in about a month or 2 so ill tell u whats going on with it then Thanks again!
