.030 over 350 vortec - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2012, 10:10 PM
Hi all, I have a 350 vortec in a 97 4x4 that I had punched out .030, heads shaved, milled for larger springs, and a 258hr-12 comp cam. Now the motor doesn't have as much torque as it did when stock, the cam seems to come on @ 3k to 35k, any ideas? I checked other forums and people that have this cam say it gives loads of low end torque?? thanks in advance!!
Old 08-12-2012, 12:36 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Verify the cam phasing and the ignition timing.
Old 08-12-2012, 06:07 PM
Coppertop's Avatar
Have you had your programming re-vamped? Have a 96 chevy with a vortec. Decided to put some aluminum heads,1.6-1 roller tips to give it A full roller valve train,a set of headers and noticed a very slight gain in power. Then I programmed it and son of a ***** what a difference! Even with just a hypertech max energy programmer. You might wanna swap out the poppet injectors for the replacement ones cause they cause problems and won't support anything more than 375-380 hp and they don't even do that well.
Foot to the floor,hair back,knuckles white!
Old 08-14-2012, 06:30 AM
Thanks for the insight, I have checked initial timing it's good. Coppertop you said to reprogram..As in chip it? I asked the builder about that earlier and he,said with the cam as short as it is that it wouldn't need a chip. I asked him also if he had degreed it and he just looked at me..lol, he is friend just helping me out, (sigh)
So, even if the cam is straight up it should do better, I guess chipping is in it's future. Appreciate the thoughts!!
Old 08-14-2012, 10:03 AM
Banned
You are running headers right? And reprogramming is needed.
Old 08-14-2012, 10:23 AM
engineczar's Avatar
You do need to confirm the cam timing. I had a friend who installed a cam in his 360 Mopar and did not degree it in. He installed it straight up dot to dot. Which I confirmed when I took it apart. The cam card recommended a 111 intake centerline. When I checked it the cam centerline was actually 121 degrees. 10 degrees retarded. It was a new cam with a new timing set so even though the installation was correct something in the tolerance stack was off. His engine had some of the same symptoms. A cam that should pull good down low but didn't start pulling until high rpm's.
BSE Racing Engines
Old 08-14-2012, 05:33 PM
bigdog7373's Avatar
Of course it's fast
Yes you must reprogram it. You have more displacement, more compression, and more cam, but the computer is still controlling it like it's a stock low compression 350.
Old 08-20-2012, 02:44 PM
Yes engineczar..I still haven't found out if this cam has advance ground in it, but I see that degreeing will have to be done and/or a chip. Thanks for the thoughts!!
350 X .030 over is 361....Correct ???? meikotom Hotrodding Basics 4 09-09-2011 01:29 PM
putting 305 vortec heads on an pre-vortec 350 thor1022 Engine 11 01-12-2011 04:17 PM
350 bored .030 over parkerbrother12 Engine 5 05-24-2007 02:34 PM
Clevite 350 .030 over flat tops 1980 Malibu Engine 13 08-04-2004 08:33 AM
.030 over 350??? Mightymouse Engine 21 06-18-2004 05:48 PM
