.040 over 305 cam choices - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2006, 10:59 AM
DHMag's Avatar
right now, im running a Lunati BracketMasterII 00016 cam and lifter kit. while im not quite satisfied with its performance, ive been thinking about 2 other cams. both are Melling cams, one with 204/214 duration with .420/.443 lift and the other is 214/224 duration with .443/.465 lift. the Lunati has 218/218 duration with .458/.458 lift.
the motor has stock Q-Jet carb, dual plane intake, Dynomax headers with 2 1/2" dual exhaust.
which cam would you chose for your 305, theoretically speaking ?
Old 05-09-2006, 11:09 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Theoretically speaking, since I know nothing about your car or what you are trying to accomplish,
I would go to CompCams and step into the XE-H series cam and stick with a .050 duration of about 210. After all, this is not a 400+ cubed SBC. Note: Your valve lift might be limited by your heads and springs.
Cam lift and duration numbers compared brand to brand mean virtually nothing.
Also I bet you need a good distributor curving and carb tuning.
305 cam removal???? jajeff22 Engine 7 06-05-2005 05:16 PM
305 cam handyman Engine 2 09-07-2004 12:22 AM
305 with a ZZ4 roller cam shane7643701 Engine 3 06-08-2003 11:21 AM
stock 305 heads and cam 85 regal Engine 3 12-12-2002 08:41 AM
86 - 305 what cam? Iroc'o Engine 2 10-09-2002 05:43 PM
