041 heads
Hope everyone out there is doing good. I got a set of 041 heads from a bud of mine with all the good parts to get them re-done. Heres the list of things he give me. is there anything that I'm missing? thanks for the help
Howards Cams Street Series Retrofit Hydraulic Roller Lifters
Valve Locks, 10 Degree, 1-Groove, 11/32 in
Pushrods, High Energy, 5/16 in. Diameter, 7.266 in. Length
Valve Springs, Single, 1.265 in. Outside Diameter, 425 lbs./in. Rate, 1.150 in. Coil Bind Height,
Guideplates, Flat, 5/16 in. Pushrod Size
ROLLER ROCKERS 1.5 3/8 STUD
3/8" ROCKER ARM STUD KIT
Valve Stem Seals, Dupont Fluoroelastomer, Positive Stop, 11/32 in. Valve Stem
Valve Spring Retainers, Chromemoly, 10 Degree, 1.250 in. O.D.,
