Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 041 heads vs 305 HO heads
Old 12-15-2012, 12:57 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
The 041 cylinder head is one of the best of the best OEM 60's era high perf SBC cylinder heads.
Especially when ported to improve flow. Whether the swap pays off for you is debatable.
I make very good power using 305HO heads after generous porting and larger 1.94 valves (1.94x 1.60 best)
so these heads have very good power potential once generously tweeked, also.
(They are both "stock heads" in OEM as cast form and both get a whole lot better with judicious porting.
The 041's have better ultimate potential, if reworked and ported correctly)
Many of these old OEM hi perf heads are worth more to you in stock form sold to a restorer
or NHRA class legal Stock eliminator SuperStock engine builder that needs them, to allow
funding to get a much better aftermarket cylinder head. (Brodix, Profiler, Dart etc) Miles ahead in power.
If you really want to feel the power when you rug it, get some 4.10's.
