041 sbc heads,should I buy them? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2008, 06:20 PM
Last journal entry: dash mods
I found a set of 041 heads,they have fresh Manley 202 valves, guide plates,new springs ,but not hardend seats.Price $350, should I buy them and run them as is, or will I have problems with the old seats?If I have to redo the seats it'll make them too expensive, thanks Cisco
Old 03-03-2008, 06:26 PM
In the end, where-ever and when-ever that happens, the seats get pounded out. However, in the big picture on the street in ordinaryish commuter kind of driving they seem to last about as well as the valves of these heads back when lead was king, give or take 30-50 thousand miles between valve jobs.
So consider how you'll use 'em and go from there.
Bogie
Old 03-03-2008, 07:06 PM
Oldbogie, I think you just told me they last Ok if I don't pound the car?LOL They have sleaved exhaust guides,do these hold up?I'm building something to just cruise in. thanks bud , Cisco
Old 03-03-2008, 07:41 PM
DoubleVision's Avatar
You can buy lead additive also, this is what I used when I used 041 castings.
Old 03-03-2008, 07:48 PM
lead additive is about $8 for a tank of gas and can't always get it.I used it when the car was a stock 38 chev,,Cisco
Old 03-04-2008, 06:57 AM
They are good heads for $350 if the machine work is fresh I'd buy them. Assuming you're on a budget you could run these for now and save some money for a good set of aftermarket heads with hardened seats and then sell off the 041's for the same money you paid or more.
Old 03-04-2008, 10:26 AM
Yeah, non-hardened seats hold up in ordinary service with unleaded fuel about as long as valves did with leaded fuel. The erosion panic is left over disinformation spread by those who didn't want unleaded fuel to become the norm. The argument totally disregards the point that with lead in fuel, valve life wasn't all that great but seats generally didn't have problems. The reasons for short valve life with lead is that lead precipitates on things, valves in particular. So the valve was coated with a material that caused them to run hotter, thus burnt valves were a constant problem. So was fouled spark plugs. There was no such thing as 10 -20 thousand miles on set of plugs. Plugs would foul out in a few weeks so that every month or two you had to pull 'em, clean 'em and re-gap 'em. For an engine with heavy spring pressures such as needed by aggressive cams, the wear issue quickly becomes a problem because of the higher loads and RPMs associated with this use, in that case you'd want a modern head with hardened seats.
Replacement guides are there to repair wear of the original guides, they usually use bronze alloys which better suited to the job than cast iron. So tighter clearances can be held which reduces oil consumption from that which gets thru the guide to stem clearance. This also helps reduce deposits that form on the back side of the valve.
Bogie
SBC Heads interchange JasonKyle Engine 5 05-06-2006 08:08 PM
SBC 400 Steam Holes w/L-98 Heads?? ezobens Engine 17 02-24-2006 01:50 PM
getting old iron heads to flow? (SBC) KNanthrup Engine 9 12-21-2005 05:06 PM
041 heads on sbc 400 JoJosz28 Engine 10 12-30-2004 06:52 AM
041 heads on sbc 400 JoJosz28 Engine 2 12-29-2004 11:05 PM
