05 Nissan Titan - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2007, 07:56 AM
05 Nissan Titan
I broke a valve stem lsat night trying to get the ^&*^(^ cap off that the tire installers must have cross threaded. My wife took it in to get the stem fixed and they told her that the air pressure sensor is in the valve stem? and will cost $60 to replace. Does that sound right?
Old 12-05-2007, 08:11 AM
Yep, welcome to the world of computer controled cars.
Old 12-05-2007, 08:25 AM
powerrodsmike's Avatar
Wiki Edits: 161
My tire guy said those things will be mandatory on all new cars starting next year or so..
Wild huh?
Mikey
BE different....ACT normal.
Old 12-05-2007, 09:07 AM
dtcandyman's Avatar
Last journal entry: Time to let go
What probably happened is that a steel cap was installed instead of the factory aluminum cap. The tire pressure monitor you need is part#40700-ck002.It retails for $93.75....make sure you get a factory cap or else the same thing will happen.(trust me, i work for nissan dealership)
Old 12-11-2007, 02:07 PM
Candyman,
The wife took it to WallyWorld to have the valve stem replaced. I find it hard to beleive that they had one in stock for the titan so I'm not sure if there is a universal type or not but my dash light is still on. The guy said something about resetting things to make it pick up the new sensor. Can you offer any insight? Thanks!
Old 12-11-2007, 02:24 PM
dtcandyman's Avatar
Yes, they have an electronic "tool" that helps the system learn the new sensor,almost like programing a remote to a car.
nissan titan cylinder heads cuervo_1979 Engine 1 11-19-2007 02:03 PM
Nissan Titan Chip tumbleweed1 Engine 0 07-17-2007 03:01 PM
Nissan launches self-repairing paint x711 Body - Exterior 10 05-28-2006 11:05 PM
360Dodge in 96 Nissan P/up wiring questions rossov Electrical 4 05-03-2006 05:55 PM
interchangable engines and trannies for 1994 nissan maxima siuol012 Transmission - Rearend 1 11-20-2005 05:51 PM
