06 Denali Limp Mode - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2010, 09:12 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
06 Denali Limp Mode
I was out ( looking at a 73 Mustang) with my buddy Peter last weekend and his truck all of a sudden had a couple of engine lights come on and the truck went into limp mode. He pulled over ,turned it off for a bit and then started along OK after that.
When we got back to my place, we threw the scanner on it and got no codes even though the SES light was on.
Cleared the light and lasted 2 days. It keeps going into limp mode a couple times a day now.
GM can't find the problem w/o a trouble code coming up.
Any thoughts?
Thanks,
Pugsy
Old 03-04-2010, 10:26 AM
tnsmith10's Avatar
when will it rain???
what are you using to retrieve codes with?
also with you describing it going into "limp" mode (3rd gear only), kinda tells me that the trans is not getting power. a cycling of the key and it starting to work again, could indicate a bad ignition switch, which is quite common.
Old 03-04-2010, 10:37 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Whoops, I've heard of limp mode, wasn't exactly sure how it works.
He told me its not going above 2000 rpm's.
I'm using Auto Inginuity to scan.
I've heard of the ignition switch.
Perhaps we should start there?
Old 03-04-2010, 11:32 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I've had my '09 Duramax go into reduced power mode when I had a bad injector. RPM's were limited, almost zero power and I was able to 'limp' to the dealer. Tried restarting twice, the last time at the dealer it would not start. This all started with gelled fuel from the cold. Got it thawed, some #1 fuel then the injector problem reared it 's head.
Why they go into limp mode I would like to know too.
Semper Fi
Old 03-05-2010, 04:59 AM
tnsmith10's Avatar
i would recomend a snap-on or otc scanner. i have a feeling that the scanner being used is not able to retrieve stored codes. another thing is also, with what your describing, that its being checked for codes after its been shut off and that could wipe the code from current and that could be why its not getting any codes.
1 thing to check for when it happens is to check for power down at the trans, before buying parts. id hate to recomend buying anything until the cause is certain.
Old 03-05-2010, 06:49 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Thanks.
What happens when they hook up the snap on and it doesn't show anything?
I believe the dealer has never had a handle on it.
So many possibilities , it boggles the mind.
Computer, ignition switch, wiring harness,.....
I'll tell him to get it scanned somewhere other than the dealer and see what they come up with.
Old 03-05-2010, 10:22 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
My buddy just came into my office with a new symptom.
The left hand turn signal is malfunctioning and it works if he wiggles the key.
Looks like the ignition switch.
Old 03-06-2010, 04:39 PM
tnsmith10's Avatar
could be, if anything, it doesnt take a whole lot to investigate and take a look. the last one i did, you could clearly see the corrosion build up and see that the problem was in the switch.
Old 03-06-2010, 04:50 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Thanks.
He will get his mechanic to check it out.
Will post results later.
Pugsy
Old 03-10-2010, 05:07 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Well, he hasn't made it to the mechanic. Stubborn maybe.
I think he was waiting for it to happen on the way home which is right past my house. Happened today.
He pulled in and I retreived a code PO121 throttle pedal position/switch A circuit range/performance problem.
Also got a PO60e....undocumented trouble code description.
Any thoughts?
Thanks.
Pugsy
Old 03-10-2010, 06:14 PM
tnsmith10's Avatar
Any thoughts?
Thanks.
Pugsy
here i am thinking when you brought this up that it was a trans problem when you mentioned limp mode... lol
a P060e ive not seen, but anthing in the po600 area is a ecm or keep alive memory problem off the top of my head. a po121 indicates a tps problem, and with what i just re-read about the only getting 2000 rpms out of the motor tells me theres a problem with the accelerator pedal position switch as well,
Old 03-10-2010, 08:17 PM
I don't believe you can get the throttle sensor seperate, the gas pedal assembly will need replaced if so.
4L60E Limp Mode hardwurkindaddy Transmission - Rearend 4 11-14-2009 09:29 AM
guided mode pepi Off-Topic 1 02-11-2007 07:26 AM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
