06 dodge ram shakes when braking - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2010, 01:56 PM
i replaced the front rotors and pads, still shakes when braking with new brakes, is there any suspension parts that may cause it to shake when braking? thanks
Old 10-09-2010, 03:08 AM
SSedan64's Avatar
Originally Posted by JadeCrew
dude did you go to the shop to check if it has any dodge auto parts that got affected when you replaced the pads?. i think thats the problem.
Spammer suxxx
Old 10-09-2010, 07:48 AM
car enthusiast
Last journal entry: Future Build: 1927 Dodge 5 window coupe
Sadly the 2006 Dodge has some serious issues and Dodge has put out a TSB for the shaking: TSB 02-001-07 REV. A........Basically, the lower front and rear control arm bushings were inadequate for this type of vehicle and cause the truck to drift one way or another and cause a shudder when braking. So, you will need to replace the control arm bushings to stop anymore damage or worse, wrecking the dodge...
Old 10-09-2010, 08:12 AM
Irelands child's Avatar
I guess that's worse then the well known (by Ford and others) 49mph rear bounce on my '06 F350.
One thing - many garages and do-it your selfers slam the lug nuts tight with an impact wrench or breaker bar instead of a torque wrench and can and do ruin brand new rotors. Been there with an old winter beater Torino I owned in the late '80s - and I was the culprit. And knew better
Check the rotor runout before you do the recommended bushing check
Irelands child
Old 12-19-2010, 08:19 PM
goodyear tires may be warped
i have the same year truck with th factory 20 inch rims that came with goodyear tires, my tires had plenty of thread left but for some reason they beacame warped and would cause the same problem your describing, i know of a couple other guys with same proplem. after i replaced the tires i no longer had the problem. and by the way your truck had a factory recall on the front hubs and bearings if you didnt know, my hubs and bearings were replaced in 07 whitch the factory paid for but went out again last week, i had to come out of pocket fot that repair.
Dodge Trucks Now Just Ram? crystalbluevib Hotrodders' Lounge 7 05-31-2010 11:23 AM
dodge ram truck kkuzmicki14 Introduce Yourself 3 10-08-2009 11:08 PM
Dodge Ram 2500 concerns before purchase kadi Hotrodders' Lounge 9 09-26-2008 03:47 PM
1990 dodge ram and fifth wheel heman37 Suspension - Brakes - Steering 5 06-14-2007 10:24 PM
Dodge 1987 mini ram van (cargo) - info help? joe99 Engine 8 02-04-2004 11:33 AM
