06' Freestyle: Egr Valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2010, 11:16 AM
The mobile view is crap
My mother has a 2006 ford freestyle and it is giving her a check engine light due to the egr system. I am looking for the egr valve but can't seem to find it. Don't even really know what it looks like. I was wondering if anyone knew where the valve was on this vehicle and if the valve can be cleaned. When she had it scanned at auto zone it told her about every part in the egr system. I figured maybe the valve itself needed to be cleaned.
Old 09-05-2010, 11:27 AM
LATECH's Avatar
It could be one of three designs. What are the specific codes you have?
Chances are its not the valve but the passageways that are plugged. It could also be a bad regulator or a bad delta sensor.
In each intake port there is a restrictor where exhaust gas is injected ( when requested by pcm) these can plug sometimes one or two at a time and can cause a misfire as well as an insufficient flow code.
Post the code numbers and I will look to see if i can determine which system you have and where to look for trouble. Latech
Also which engine do you have 3.9 or 4.2 ?
Old 09-05-2010, 12:35 PM
406 bug's Avatar
9.82 @ 139mph
You may want to check the warranty period in your owners manual. Some of the auto manufactures have extended periods for emission systems - Like 8 years or 80,000 miles. Just a thought.
Old 09-05-2010, 05:05 PM
ok i will check on warranty, i will also post the codes later on, i can't get a hold of her right now but I will sometime tonight then i will post the codes
egr valve cuttouts for intake manifold gaskets? hemi joe Engine 15 06-30-2010 01:38 AM
can i do away with egr valve? Fordy8man Engine 15 08-23-2007 01:45 PM
EGR valve operation rick458 Engine 1 02-16-2005 12:10 AM
How do you know if your EGR valve is working??? Munchos90 Engine 15 01-26-2004 09:29 PM
EGR valve?? zeeman19 Engine 4 07-05-2002 09:09 AM
