Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 08 jeep wrangler slinging grease and making a scraping sound near transfer case
Old 11-21-2012, 06:15 PM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
If your chain wore thru the case you would be leaking Red atf. Your problem is probably in that funky joint assy in the front.
A driveline shop could make you a real shaft for the rear.
The Following User Says Thank You to prostreet6t9 For This Useful Post:
laney (11-27-2012)
