1 1/4" MC piston...! - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2010, 02:51 AM
staleg's Avatar
Last journal entry: Hand brake
Summit sent me the a wrong Corvette MC and since I live in Norway, a return of such a heavy item was out of question. They offered me a 50% refund and keeping the part, which I accepted.
I have measured the MC piston diameter and it measures 1 1/4"!
I'm building my own pedal/booster set up with a 7" single booster and 7:1 pedal ratio. The car has GM discs in front and Jaguar discs at the rear.
What I should have was probably a 1 or 1 1/8" MC...
Do you think the 1 1/4" will work, or is it to big and will result in a very hard pedal?
Old 10-16-2010, 08:20 AM
Considering you have a 7:1 pedal ratio, it'll probably make up for that and work fine.
Old 10-16-2010, 03:00 PM
techinspector1's Avatar
Wiki Edits: 326
I would have to agree with Matt. Power brake systems usually use a ratio of around 4:1, Manual systems use a ratio of around 7:1, so the pedal ratio should cancel out the larger bore. Looks like you're stuck with the 1 1/4" bore anyway, so make the best of it. I'd sure be interested in hearing back concerning how this turns out.
Old 10-16-2010, 03:44 PM
I'll third the 7:1 ratio..
I have a 1" bore master and with 10" of vacuum to the booster, I would have a hard pedal the last 10' of the stop. I changed the pedal ratio to the manual setting, 6:1 and it works fine..
Your set up will have much less pedal travel..
Old 10-17-2010, 03:27 AM
staleg's Avatar
Since I'm building a 90 degree transeverse set up, I can change the ratio very easy later If that's neccessary.
I' ll keep you informed, and thank you for the reply's
stroke to rod ratio jacobm99 Engine 28 12-16-2013 06:46 PM
Cam Help shsouthard Engine 18 03-29-2009 10:33 PM
383 vs 350 TheCiscoKid Engine 86 05-03-2008 04:10 PM
longest rods in std deck 454 bbc?? deuce_454 Engine 11 01-30-2004 11:06 AM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
