1/2 Chevy Disc Brake....Hollander Conversion?
Gents,
I have a 1984 1/2 ton Chevy truck with 1" rotors up front. They have the 5x5 bolt pattern. Looking to get to a 5x4.75 bolt pattern. Does anyone have access to a Hollander Interchange Manual that can then tell me if there is another rotor out there that will swap right out that has a 4.5x5 bolt circle? I heard through the grapevine that some GM vans might have a rotor with the small GM pattern that I am looking for. Any help is greatly appreciated. Thanks. Brent Last edited by 31fordcoupe; 11-13-2011 at 10:57 PM. |
82-92 Camaro / Firebird had a "RPO 1LE" option that included a 12" big brakes upgrade.
23030AA3L / 23030AA3R for slotted and drilled unidirectional versions I'd suggest calling SSBC at 800-448-7722 to make sure of the rotor diameter, bearing, and seal specs ... as they don't have that information listed. They DO say that this rotor has a 5 on 4.75 bolt pattern. Summit also lists all of these rotors as "available". |
More info
As long as your truck is equipped with JB1 or JB3 brake option (Look at the Service Parts Identification sticker in the glovebox)
I beleive that your truck uses the same calipers, pads, and wheel bearings as an 87 Caprice. NAPA #'s: AE728AM Pads 242-2028, 242-2029 Calipers BR6 Inner Cup & Cone BR3 Outer Cup & Cone 19984 Seal You can't use the NAPA rotors, however, as they only list the ones with the 5 on 5" bolt pattern.
| 63 chevy impala disc brake conversion | 63impala | Suspension - Brakes - Steering | 3 | 09-02-2007 10:01 PM |
| 56 Chevy Bel-air 150 Disc Brake Conversion/Swap | heavy2dachevy | Suspension - Brakes - Steering | 1 | 07-03-2006 01:40 PM |
| 66' chevy disc brake conversion | Hades212 | Suspension - Brakes - Steering | 2 | 11-26-2004 11:50 AM |
| Disc brake conversion for 1966 Chevy P.U. | Herb | Suspension - Brakes - Steering | 2 | 02-10-2002 07:20 PM |
