1/2" ID clear fuel line - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2013, 08:24 PM
Hi bro's,
I'm looking for 1/2" ID fuel line for my rod. I have an old beer keg for a gas tank and I've set it up to have a clear fuel line vertical to the tank showing the amount of fuel in the tank. I need 1/2" ID clear so I can see it! I'm checking the usual auto parts places and no luck. Any help?
Old 12-07-2013, 12:12 AM
vinniekq2's Avatar
clear lines are not a good idea if you plan to go to the track someday?
The Following User Says Thank You to vinniekq2 For This Useful Post:
NEW INTERIORS (12-07-2013)
Old 12-07-2013, 12:59 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
What Vinnie said, NHRA has a rule about flexible neoprene fuel lines and where they can be installed, I was called on it for my GO tri-power setup years ago at Carlsbad Raceway. Back then on the carb was OK, not from the motor to the chassis. Basically, it it can be ruptured, pulled, stressed, etc., while the vehicle is being driven, not allowed.
Semper Fi
Old 12-07-2013, 12:05 PM
4 Jaw Chuck's Avatar
I think a series of threaded sight glasses superior to the system you propose, much safer and accomplishes the same thing. All you need are a series of welded on threaded bungs to your tank, three would be all you need...one at 3/4, 1/2 and 1/4 full.
Fluid Level Sight Glasses, Fluid Level Indicators, Sight Glasses and Fill/Drain Plugs – Section 12
— Han Solo
The Following 2 Users Say Thank You to 4 Jaw Chuck For This Useful Post:
Blanceman (12-08-2013), Denny (12-07-2013)
Old 12-07-2013, 04:09 PM
techinspector1's Avatar
Wiki Edits: 326
I agree with the others that it's not a real good idea, but to answer your question, here is some 5/8" x 3/8" line......
6' Lot of 10 Clear Tubing Plastic Tygon Fuel 5 8OD 3 8ID Unused Line Vehicles | eBay
Old 12-07-2013, 05:20 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Also check Home Depot and Lowes, they have a large selection of tubing, in small take home or huge 'by the foot' rolls.
Semper Fi
Old 12-07-2013, 05:32 PM
Wiki Edits: 326
Needs to be compatible with fuel.
The Following User Says Thank You to techinspector1 For This Useful Post:
Old 12-07-2013, 05:36 PM
vinniekq2's Avatar
How about using a marine or motor cycle gas cap with built in guage?
Old 12-07-2013, 05:37 PM
Wiki Edits: 27
certified ?
Is any of the clear lines certified for Fuel? I had some clear about 50 years ago, engine heat softened it , and it started leaking and I had a fire, even though I used worm drive clamps.
Old 12-07-2013, 05:40 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I agree. When I used hardware store tubing it was in the '60's, without any problems, either I got lucky with appropriate tubing or no ethanol was my savior.
Semper Fi
Old 12-08-2013, 07:13 AM
Thanks man,
No plan to go to the track. I got an answer that using sight glass in 3 places on the tank, 1/4, 1/2 and 3/4 would work good and safe too.
Blanceman
Old 12-08-2013, 12:50 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
In that case heat won't be an issue, just compatibility like Richard said if you're still talking soft hose.
Semper Fi
Old 12-08-2013, 03:41 PM
That's an awesome idea! The only problem is I've got a 2" pipe thread for the intake and cap. I'm not sure I could find a compatible cap, but maybe I could modify it some how.
Old 12-08-2013, 03:43 PM
I think it would be good since it's not near the engine "heat", I just can't find any online!
Old 12-08-2013, 07:59 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You know, the Home Depot tubing description includes chemical usage, I've been using their 3/8 clear tubing for fuel lines on two of my racing karts, a World Formula and a Clone class, for over three years with no hardening or degrading. Of course the big box stores don't have anyone qualified to tell you if that spec includes gasoline.
Semper Fi
Strange thing happening with my clear "solvent pop"/"fish eyes" ? myfamiliacc Body - Exterior 35 02-16-2013 07:18 PM
Drive line "slip" and "jerk" with Ranger 4WD cboy General Rodding Tech 15 01-15-2011 03:36 PM
3/8" brake lines & tube nuts.. can it be used to build my fuel line? rajsid Engine 3 10-05-2009 11:54 AM
3/8" female to male flex line needed. Any cars front wheel cylinder frame line? Ripped Suspension - Brakes - Steering 2 03-12-2008 02:47 PM
FUEL LINE & TRANS LINE SIZE/TYPE leejoy Hotrodding Basics 7 11-29-2005 10:59 PM
