1/2 Rhoads??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2013, 11:48 PM
1/2 Rhoads???
I've been contemplating using a magnum 292 cam that I've had for sometime in a 383 build. My compression will be a little low for this cam at 9.45 and I was considering using a half set of Rhoads or Crane High Intensity lifters to help with cylinder pressure. Has anyone experimented with using just a half set on a single pattern cam?
Old 03-05-2013, 12:42 AM
I once used a set of rhoades lifters before, but my oil pressure was so high that they didn't bleed off at all and ended up lashing the rockers,
Old 03-05-2013, 07:17 AM
Banned
I assume you're thinking of using a set on the intake lobes only? There's no reason to worry about it- BUT with that being said Rhoads lifters are hard to predict and their action and noise is very application dependent- cam, springs, oil pressure, and oil are the main factors valve train weight can also play a role too though.
IMO I'f just get a more appropriate "white box" cam the cost is nearly the same and the results will be much better.
Old 03-05-2013, 04:51 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I have done this on a Pontiac 455, intake side. Worked fine. When I did the Pontiac, the cam and lifters were going to be replaced but that never happened because it ran fine as-is.
However, there's a lot to be said for choosing the correct cam from the get-go, and that would be my recommendation.
rhoads lifters 82c10 Engine 9 02-23-2010 04:53 AM
DO Rhoads lifters really work? skidderking Engine 13 11-27-2009 07:03 PM
Rhoads Lifters yragat Engine 18 11-25-2008 09:20 PM
Rhoads Lifters yellow69firebird Engine 20 02-20-2007 06:24 PM
Rhoads lifters dgkipp Engine 8 12-13-2003 02:22 AM
