1-2 shift hesitation - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2013, 08:25 AM
Hello fellow hotrodders,
I am having an issue with my newly rebuilt 700R4. on each drive since I reinstalled it, it hesitates to shift from 1st to second. It only does this on the first shift. After that, it's fine and the shifts are all excellent.
This morning I played with it a little to see how long it took to shift. I had the shifter in manual 2nd and the trans did not want to shift. When I moved the lever to 3rd, the trans shifted to 2nd immediately. I will double check my manual linkage today after work to be sure but this doesn't feel like a man linkage issue since it only does it once.
Has anyone experienced anything like this before? Do any of the trans gurus out there have any idea what might be causing this?
I was thinking maybe sticky governor but the gov seems to be working as the trans wants to release 1st when I let off the throttle. It just won't engage second. Not until whatever is sticking breaks loose, then it works great for the remainder of the drive.
Mods that were done to the unit include: stiff line bias spring, superior 2nd and 4th servos, black accumulator valve spring from Transgo JR kit, stiff brown 1-2 accumulator spring.
Old 03-13-2013, 08:58 AM
jakeshoe's Avatar
It may be purging the air out of the servo on the first shift.
Old 03-13-2013, 12:35 PM
Thank you jake for your reply. Ive read some of your posts and you obviously know these units. Is there a solution? I guess I can live with it if I have to. It's better than the issues the unit had before the new build. When I have a chance I plan on hooking up a pressure gauge to it. My pressures should be excellent unless I have a leak somewhere. The pump is brand new. I am running the high pressure slide spring, .500 TV boost valve and .300 rev boost valve, and I set my TV cable before I ever started it. The cast iron VB is like new, all the valves and bushings are smooth and tolerances tight.
Old 03-14-2013, 06:14 AM
Update: Yesterday as I left work with the shifter in 3rd, the trans shifted into 2nd normally right from the start. The car had sat for 12 hours, although since it was a reasonably warm day, the trans temp may have stayed up from where it is on a cool morning. This morning there was some hesitation shifting into 2nd as I left the house, but it was minor. I plan to play with this a little over the following days and see if starting out in D3 helps, it seems to. I love this transmission and I'm proud that I did it myself and that it shifts so nice. This one little issue is the only real problem.
TH400 shift hesitation chevyv8_power Transmission - Rearend 6 03-31-2008 04:14 PM
need help on converting column shift too floor shift . jody chevelle Electrical 1 11-29-2005 08:29 PM
Trans seems to shift into neutral during the 3-4 (overdrive) shift Rocketmann66 Transmission - Rearend 2 06-12-2005 10:21 AM
my tranny wont shift hard even with shift kit notmrgoodwrench Transmission - Rearend 4 08-12-2003 06:10 PM
C-6 shift hesitation billybob_v10 Transmission - Rearend 5 08-11-2003 10:09 PM
