if a dohc torque is 48-50 ft lbs.
sohc 46-50 ft lbs. you should have 10 bolts holding the head,start in the middle and torque the 2 in the middle first only to 25 ft lbs. then work your way out in a cris cross pattern,the start in the middle again and this time torque to 50 ft lbs.and then do the cris cross and your done. |
Cylinder head torque: 46-52 ft. lbs. Rod bolt torque: 24-26 ft. lbs. Torque pattern on head: 9 5 2 3 7 8 4 1 6 10 tom Last edited by machine shop tom; 05-14-2007 at 07:14 AM. |
| Torque Specs Chevy 350 | Knuckles El Creep | Hotrodding Basics | 12 | 12-15-2012 08:27 PM |
| Transfer case - NP 203 - 205 | jrm123180 | Transmission - Rearend | 2 | 03-24-2006 07:36 AM |
| torque specs. , 88' chevy 350 | leonard69 | Engine | 1 | 05-27-2005 11:30 AM |
| Anybody have wheel torque specs? | TurboS10 | Hotrodders' Lounge | 5 | 03-08-2004 02:08 PM |
| Torque Specs...Engine Builders | TurboS10 | Engine | 10 | 03-08-2003 02:21 PM |
