Is 1/4" -3/8" enough space? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2005, 10:29 AM
gator412's Avatar
1955 2nd series Chevy Pick Up
Last journal entry: Body work and U bolts
Hi all,
I am installing power steering on my 1955 2nd series truck. Once I installed the PS pump the fan and the alternator belt are both about 1/4" away from the PS pulley. So my question is is this enough room for them. I would think so but would like to have other opinions.
The attached photos are different views. In the pictures the relationship between the items seems closer due to the camera operator's abilities...err or lack there of.
Name:	PS tight fit 1.JPG
ID:	5109   Click image for larger version
Name:	PS tight fit 3.JPG
ID:	5110   Click image for larger version
Name:	PS tight fit 6.JPG
Old 05-26-2005, 10:55 AM
PapaG's Avatar
Ask me, Cause I don't know
Last journal entry: Need things to do.
It should be. Some of the factory stuff is real close together as depending what it came off of there was limited room.
Old 05-26-2005, 11:14 PM
gator412's Avatar
Thanks,
PapaG..I will post a pic when get all the components on..or as I progress.
Old 05-27-2005, 02:02 AM
Pony's Avatar
I don't have a good pic of the 351M in my 53 ford, but I wound up with about the same clearance when I was done. The fan blades flatten out as the rpms go up so Iv'e never had a bit of trouble in three years.
Old 05-27-2005, 01:38 PM
johnsongrass1's Avatar
Race it, Don't rice it!
You can use a spacer in the fan to move the fan forward another 1/2. Although not needed IMO it's a piece of mind. (gross, a piece of brain?)
Any of you guys intersted in web space? Jag Daddy Hotrodders' Lounge 6 05-04-2005 07:22 PM
Rutan's Space Venture trees Hotrodders' Lounge 12 06-30-2004 12:52 AM
Cool space flight 87442lover Hotrodders' Lounge 0 06-17-2004 12:13 AM
Filling Space Dutchman Hotrodders' Lounge 4 11-09-2003 09:59 AM
Space Shuttle TurboS10 Hotrodders' Lounge 33 02-02-2003 11:22 PM
