1/4" collet flex shaft die grinder, what kind do you use? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2006, 04:45 PM
406 ss monte's Avatar
eat a beaver, save a tree
i'm trying to find a good electric flex shaft die grinder with a 1/4" collet. i can't find anything but the small dremel stuff, & it all use's the 1/8" collet stuff. i'm looking for something i can port heads with & do some block clearance work with.
what dou you engine builders use?
Old 03-20-2006, 03:41 PM
coldknock's Avatar
I use a Milwaukee die grinder but no flex shaft. The collets on flex attachments are usually too wobbly for my taste, and safety.
Makita and Chicago Electric make decent 1/4 collet grinders as well but the Chicago collet doesn't agree with shanks longer than 4".
Larry
What's the difference between a die grinder & a cut off tool? FrankR Body - Exterior 20 12-15-2005 05:40 PM
Cheapest place to get die grinder abrasives?? leastbay Body - Exterior 3 12-21-2004 12:27 PM
Air Tool die grinder. Which one to get? fourbyfourblazer Garage - Tools 9 12-13-2004 08:11 PM
