1/4 mile with low mph - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2005, 02:09 PM
brainsboy's Avatar
brains
I ran my car at the track. I ran my first pass at 10.76 at 114mph
To me it seems that the Mph is pretty low for that time, what causes that? The 1/4 mile calculators estimate something closer to 127mph. I think my 60ft times were around 1.43
Old 10-31-2005, 02:39 PM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
All that means is that all your time is made up early on. I would say you have a lower than normal gear or more torque than you know what to do with. If you plan to bracket race the car you have that in your favor, nobody would know how to estimate themselves. My current set up has 3.08 gears an all my time is in the top end. I usually get caught around half track and really pick up on the top. Kinda fun to watch though.
Old 11-03-2005, 06:01 AM
brainsboy's Avatar
brains
What are some things that can be done to bring up my MPH? Or should I just continue working on getting my time down?
Old 11-03-2005, 06:19 AM
edge's Avatar
Time is short, are you ready?
What was your 1/8 mile ET & MPH? Also, what gear and tire size do you run?
Does it feel like it is falling off on the top end. Maybe a fuel starvation issue?
I did a comparison of a few cars to see the factor between 1/8 and 1/4 mile ET and MPH. Most the cars listed here are N/A without power adders.
http://www.edgesz28.com/edgesZ28/et.htm
Ed www.edgesz28.com
My Commitment
Old 11-03-2005, 06:35 AM
brainsboy's Avatar
brains
I have the time slip at home, but I think it was 7 somthing in the 1/8. I'll look tonight to be sure.
Old 11-03-2005, 06:47 AM
poncho62's Avatar
Wiki Edits: 5
what rear gears are you running?
How tall are the tires?
What rpm are you going through the traps?
Old 11-03-2005, 06:53 AM
brainsboy's Avatar
brains
3.89:1 detroit locker
MT 28x13.5 street ET's
First shift was a little too soon at 6000
second shift was at 6800
went through finish at 6400
Old 11-03-2005, 07:26 AM
"quickest" wins! AND IT IS A HELL OF ALOT LESS braking force and distance to stop from 114mph than it is at 130mph.....
need lots more detail on the car (motor/cam/tranny/gears etc.) to offer any suggestions.
agree with the above post, you gotta kinda' choose if you want to win the race early with "quick" (catch me if you can, my choice) or late with "speed" (I'm gonna blow your doors off top end) and that is what makes it fun
Hey! Your in the 10's.....be happy
Old 11-03-2005, 07:49 AM
brainsboy's Avatar
brains
408ci windsor
4" stroke 6.20" rods (1.55 rod ratio)
10.68:1 compression
Rings gapped .024 /top ring .350 low (made for nitrous havent run it yet)
Heads Aluminum 215cc runners, 2.08/1.60 64cc chambers
flowed cfm around 285/210 @ .500
1-3/4 headers 3"exhaust down to 2.5 for flowmasters(running full exhaust)
Cam Hyd roller - 294/300 (242/248) .576/.600 110 ls
Trans Full roller C4, 9.5" supposed to be a 4000stall probably only get 3300
Lightend drums and Manual Valve body.
Ford 9" 3.89:1 gears with detroit locker
Tires MT's 28" 13.5 wide
Total weight at the moment is 2580 with my big butt in it.
___________
So you basically saying dont worry about the mph?
Old 11-03-2005, 09:05 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
EXACTLY. Which is faster -- 10.76 @ 114 mph or 10.83 @ 120 mph??
Old 11-03-2005, 10:02 AM
poncho62's Avatar
Wiki Edits: 5
One is faster, the other is quicker.......
Old 11-03-2005, 10:16 AM
brainsboy's Avatar
brains
I'm going back to the track this saturday. Any suggestions before I go? Im bringing my carb kit, so planned on playing with some different jettings. Right now the timing is set to 12degrees at 1000rpm and 34 total advance. Any ther idea's? I havent used the nitrous yet but with it I want to get into the 9's, I'm just trying to tune things up before I use it.
Old 11-03-2005, 10:21 AM
poncho62's Avatar
Wiki Edits: 5
I figure, since you are going through the traps at 6400, you aren't going to get much more speed out of it............wonder if your torque converter is slipping?
Old 11-03-2005, 10:33 AM
brainsboy's Avatar
brains
How do I tell if its slipping?
Old 11-03-2005, 12:34 PM
yeah, your slippin' about 10% to much......28" tire with 3.89 gears at 6500rpm = 139 mph if all is perfect, (139x.90%=125mph= "real world")
28" tires with with 3.89 gears at 5500 rpm = 117 mph if perfect, close to your 114mph
so your slippin approx 1000 rpm in the tranny at top end top.....
with as much torque and HP as you have beatin' on those poor C-4 bands it not to surprising
??? You are using "Type F" tranny fluid only in the C-4 ???? if not that can cause the slippage
1/4 mile questions voodoosurfer Hotrodding Basics 37 10-23-2005 11:36 PM
Horsepower & Performance Formulas/Calculators edge General Rodding Tech 7 08-13-2005 06:01 AM
1/4 mile guess 347mustang Engine 7 07-30-2005 08:13 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
LS1 Camaro 1/4 mile times NAIRB Engine 3 04-18-2003 05:19 AM
