1/4 mile opinions on setup ? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-17-2008, 09:25 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Originally Posted by chevy350_Camd
Okay Im a little ingnorant On the numbers side of this so Im not following what would I need to to use 4.53 gears nd have insane times with the setup, or could I build the th 350 with 4. 53 gears and have a reall jumpy truck ? Can you alter the gears in a tranny so that its really good at the 1/4 mile ?
The math is somewhat easy. The gear ratio of the tranny times the gear ratio of the rear tells you how many times the engine turns for every one revolution of the axle.
So, in the case of the 700r4, 3.06 first gear ratio times 4.56 rear gears means that the engine will turn 13.9 times for every one turn of the axle. That's a little excessive. A T56 with its 2.66 first gear and 4.56 means the engine turns 12.13 times for each axle turn. That's a little more realistic for your combo.
So, its not the tranny gears that have to change, but you have to know the tranny ratios before you can pick a rear ratio. I get so frustrated when people say things like "3.73 is a good street gear," because with a T56 that's a pretty conservative cruising mileage choice, but with a TH400 its a pretty racey choice.
The OD ratio will cut down on RPMs the same way a higher rear gear would. A T56 with 4.56 rear gears would have the same highway RPMs as a TH400 with 2.28 rear gears. Big difference.
  #17 (permalink)
Old 10-17-2008, 09:28 AM
chevy350_Camd's Avatar
VROOOM !!!!!!
Last journal entry: This is the Rough Draft of the V8 Frame
1/4 Setup
Okay curtiz what yould you suggest for my truck to runs in the 12s 13s ?
Thanks
  #18 (permalink)
Old 10-17-2008, 09:30 AM
Hey Camd, just for reference 2004 SSR, 5.3 liter, the two of us weigh 5000 lbs. 294 rwhp 4.56 rear gear 15.1 et 1/4 mile at 96 mph.
1978 pontiac firebird, 355 cu in. never dynoed, nicley moded, 3.73 gear 12.3 et @ 108 mph
Never thought either one would run this quick. Just build it then start tweakin.
Bud
  #19 (permalink)
Old 10-17-2008, 09:32 AM
VROOOM !!!!!!
1/4 speed
Okay but does anybody have a guessestimate on this setup 1/4 speed.
Would this work better, a th 400 with 4.53 gears ?, How many gears does a th400 have ?
  #20 (permalink)
Old 10-17-2008, 08:33 PM
VROOOM !!!!!!
1/4 setup
Alright, I wanted to discuss if this setup would be good in a 1985 Chevy Silverado 1500 at a quarter mile
The trucks weighs 3890 alomst 4000, the motor is a 383 with a 750 cfm double pumper holley, A edelbrock Rpm manifold, thumpr cam with 500-517 lift with 300 310 adv duration, Edelbrock Rpm heads, and Flowtech headers, forged bottom end assembly, th400 with 4.53 gears.
I was wondering if anyone would have a clue to adavantages and disadvantages at a quarter mile. I do not have the forged assembly but thats all I need.
I was hoping this it would be around 14-12 seconds, with slicks
Thanks
  #21 (permalink)
Old 10-20-2008, 03:51 PM
I have a 1997 reg can shortbox, weighs 4000 lbs. With 4l60e, 4.10 gears, it has run a 14.8 at 94mph with a 2.007 60 ft, with a stock Vortec 350, air intake K&N, Hooker 2462 hkr longtubes, dual 2 1/2" exhaust with cats, Ed Wright Fastchip PCM tuning.
Stock it ran 15.7-8 at 85mph.
Stock Dodge 500 pace trucks with the 360 and the the Dodge factory installed performance ignition a factory performance headers/exhaust ran high 15's.
I had a 1984 long box reg cab, stock 1989 roller cam 305 longblock, Weiand Action+ intake, Quadrajet, in cap HEI dizzy, Hedman 1 5/8 x 3" lontubes, 3.07 12 bolt rear, 315/70/15 tires and ran a 17.4 at 84mph through a THM350 trans.
454SS trucks run low-mid 15's at low 80's for mph. The 90 SS runs a 400 trans with a 3.73 gear(they are rated at 230hp and 375 ;b/ft torque, the 91-93's run a 4l80e(same ratios as 400, but with a .75:1 OD) and are rated at 255hp and 405 lb/ft torque. These trucks are heavier as they have the 4l80e and 14 bolt rear end.
You DONT need the forged assembly. A cast 383 will do just fine, unless you are pushing over 500hp,6000 rpm REPEATEDLY or are using nitrous or forced induction.
peace
Hog
estimated 1/4 mile time?? tirefryin_s10 Hotrodding Basics 7 10-20-2006 12:54 PM
How to figure 1/4 mile speed and time? Rickand emily General Rodding Tech 3 05-02-2006 01:41 AM
My 1/4 mile times. HemmiGremmie Engine 8 12-13-2005 01:55 PM
HP estimate from 1/4 mile Blazin72 General Rodding Tech 3 10-15-2005 10:24 PM
Powertrax Locker: 1/4 mile time increase? purple1967camaro Transmission - Rearend 3 04-12-2004 07:23 PM
