1/4 panel question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2002, 10:27 AM
1969 Camaro owner
Question 1/4 panel question
My 1969 Camaro has new 1/4 panels welded in with no rust on the welds, but no flange was put in on the original-new seam so the panel sticks out there (overlapping onto the old metal, 3/8ths down from the top body line), also there are what looks like rivets near the wheel wells which are sticking up as well. What can I do to fix these problems?
thx for any help!
[ May 02, 2002: Message edited by: Johnny Bravo ]
[ May 02, 2002: Message edited by: Johnny Bravo ]</p>
Old 05-02-2002, 07:03 PM
Post
If the 1/4 is welded on the seam grind the welds down. Then you could put body filler in where the over lap is and smooth it up to the the body line. As far as the rivet looking things you could probably grind those off and fll in the grind marks with some body filler also. But I would make sure that these rivets aren`t holding the 1/4 in place. If this is the case I would put welds in before grinding the rivets.
Old 05-02-2002, 07:08 PM
Post
I would have to concur with Big Dreams. seems to me the only sensible course of action. Good luck
Another custom door panel question 1970CDV Interior 5 02-17-2007 07:47 AM
Help! What To Do With These GIGANTIC Dents!? mistermuscles Body - Exterior 14 09-16-2005 05:24 AM
53 Ford F-100 panel reassembly question Z-Money Pit Body - Exterior 1 09-11-2005 08:43 PM
Metalshaping/Body Panel Fabrication Randy Ferguson Body - Exterior 15 06-06-2005 11:01 PM
Quarter Panel Patch Ron M Body - Exterior 1 07-27-2004 01:12 AM
