1/4 replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2005, 07:30 PM
1/4 replacement
I have been working on my 1970 Lemans passenfer 1/4. Have replaced the
outer wheel housing and am preping to proceed with the quarter. Do I need
to apply adhesive to the lip of the wheel well or will a good coat of my seam sealer sufice after spot welding? I have been reviewing alot of info on the site and it has been excellent and very informative. I will attach some pics soon. Thanx
Cory
Old 10-28-2005, 03:31 AM
adtkart@aol.com
I apply seam sealer after any welding is done. It is my understanding that the adhesives will give way under the heat. In fact, when we remove a "Glued panel", we use heat to do it. I would spray it with weld thru primer, install the panel, then go back and use seam sealer there you can get to, in order to avoid corrosion problems later from trapped moisture. If possible, painting the area before seam sealer, will also help prevent corrosion, although some feel it is better to paint over the seam sealer.
Aaron
Old 10-28-2005, 06:51 AM
Thanks Aaron sounds good. I m going to try for this weekend to get it done.
cory
1/4 panel replacement (butt weld?) DusterNut Body - Exterior 37 10-04-2005 07:18 PM
1/4 panel replacement IROC100 Body - Exterior 14 03-26-2005 07:42 PM
Please desktop dyno this 454 wo/aftermkt heads that ran a 13.1 on its 2nd 1/4 ever elukas Engine 7 01-03-2004 01:24 PM
How to get 1/4 mile times from 1/8 mile. Rubberman2003 Hotrodding Basics 7 11-18-2003 11:35 PM
mopar 9 1/4 backing plate for brakes shortsuperbird Transmission - Rearend 2 10-28-2002 12:46 AM
