1.4 spray nozzle primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2011, 03:28 PM
Marty7n's Avatar
Last journal entry: Lancer face lift
hi i have a 1.4 nozzle Aurita H.V.L.P traditional spray gun and i bought Max Meyer HS filler 3011/MaxMeyer MS Hardener 8000 i wasa wondering is my nozzle the correct size to spray this primer?
its to be mixed 5:1 as recommended!
could really do with the help on this one guys!
Old 04-11-2011, 04:16 PM
milo's Avatar
point on positive
That tip will work fine. The PDF file here indacates there is a thinner available to adjust the viscosity after mixing if needed. It should be about as thick/thin as water to flow through that tip..
Old 04-11-2011, 04:55 PM
Marty7n's Avatar
just read the pdf myself,but does the thinner not require to be in an oven??as i am doing it in my garage at home! also maybe i could just buy a 1.6 mm nozzle!i only have one gun,im wondering will i need more than one gun to spray the car!
Old 04-11-2011, 05:44 PM
Underground's Avatar
Last journal entry: 54
Go buy a cheap primer gun and save the other for paint. You should never paint and prime with the same gun. No matter how clean you think you have it, you will ruin a paint job when the gun spits primer while you are painting.
Old 04-11-2011, 05:46 PM
Marty7n's Avatar
thanks underground i am definetly doing that as to be safe with my jobs,what is the reccomended nozzles sizes for??
spraying???
PRIMER?
paint??
clear coat???
i should have a gun for each by rights i'd say! be a lot less messier!!
I have $100 will you sell me a garden spray nozzle made in America? PLEASE! MARTINSR Off-Topic 10 03-10-2010 02:16 PM
can't spray k2 primer wildthing Body - Exterior 7 08-01-2009 03:58 PM
spray can primer 75sprintguy Body - Exterior 10 08-26-2007 06:24 PM
can i spray epoxy primer over etching primer without sanding? wickiewicked240z Body - Exterior 1 08-29-2006 09:07 PM
spray can primer help? napier Body - Exterior 5 02-15-2005 07:35 PM
