1/4 turn quick fastener help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2011, 11:04 PM
need help to install 1/4 turn quick fasteners.
- how are the springs attached
- the same with the flush head fastener
- what size of holes are needed
- are the mount bracket and the body panels touching
using Moroso 71500 and 71552
photos would really help
Old 05-07-2011, 04:13 AM
BOBCRMAN@aol.com's Avatar
Springs are usually held on with rivets. Size of hole is determined by the fastner/wire size. What do you have?
Old 05-10-2011, 06:13 AM
dirtracer8c's Avatar
Try here
http://www.panelfast.com/
I use these alot on my race car. If you have any questions let me know. Find what grip length you need first. I use a uni bit to make the hole the same size as the fastener.
Schiefer/Eaton Quick Chg.--Info Needed majic Suspension - Brakes - Steering 3 11-14-2009 02:17 PM
Fastener Restoration stinger12 Suspension - Brakes - Steering 3 08-03-2007 07:47 PM
turn signal problem, need quick fix 71gtx Electrical 6 06-09-2004 06:52 PM
quick answer needed douhavit Engine 4 05-28-2004 10:50 PM
help needed quick jb86 Hotrodding Basics 2 09-23-2003 11:23 AM
