1.5 to 1.6 problems rpm change - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2008, 07:57 PM
I have a 482/494 with 1.5. roller rockers. I am looking to get more power, If I change to 1.6 will the rpms change? Can I use the same rods? What problems might I have? Is it worth it?
It is a 355 with trickflow heads.
Old 04-30-2008, 08:30 PM
68firebird
what cam are you using? The duration should stay the same as long as your valve springs can force the valves closed. The 1.6 will open the valve more allowing more air flow. So it's like running a higher lift cam without all the issues you run into with high lift cams...
Old 04-30-2008, 09:21 PM
DoubleVision's Avatar
want more power? go with a single pattern cam. Chevy heads in stock form flow far better on the exhaust side than the intake side. Ford heads are just the opposite. Higher ratio rockers are good for about 1 degree more duration and .030 higher lift, as a example going from 1.5 to 1.6.
350 SBC doesn't idle, other problems too. ajax1 Engine 17 02-25-2008 08:33 PM
Belt Keeps Flying Off at High RPM - Why? leejoy Engine 67 02-21-2008 12:12 AM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 08:50 AM
Is 2 1/2 pipes big enough? Mustang_Killa66 Engine 7 02-12-2004 09:04 AM
Single plane and duel plane manifold stonedchihuahua Engine 21 01-07-2003 12:56 AM
