1.5 OR 1.6 rockers??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2012, 09:25 PM
Ok I have the comp 280h cam should I keep using my stock 1.5 rockers or would it be better to use the 1.6 rockers? How much more lift would it give my cam? right now my lift is 480.
Old 08-23-2012, 09:49 PM
vinniekq2's Avatar
1.5 rockers.If you want more lift get a bigger cam
Old 08-23-2012, 11:51 PM
malc's Avatar
Born To Be Mild
Are Roller Rockers Worth It? by Marlan Davis.
Old 08-23-2012, 11:52 PM
1.5 ratio rockers with a .480 lift cam
With the 1.6 rockers ... lift would be .512
Old 08-24-2012, 10:24 PM
when I change my rockers to 1.6 can I still use my old push rods?
Old 08-24-2012, 10:30 PM
If they were correct for the 1.5's, they should be fine with the 1.6s.
Depending on what heads you have, you will need to check for pushrod contact against the head where the pushrod passes thru. Increasing to larger ratio rockers inreases the front to back sweeping motion of the pushrod.
Old 08-25-2012, 02:26 PM
Silver Surfer's Avatar
Advanced User
Last journal entry: Test Drive (finally)!
+1
I would avoid 1.6's.
These guys actually used a dyno for this question and found that 1.6 rockers lost 40 horsepower.
Adding Power Using Rocker Arm Ratios
Old 08-25-2012, 03:10 PM
Richiehd's Avatar
JS-70
I had a set of Scorpion 1.6 rollers on my skiff motor with solid lifters. I found them noisy even when tightening up the lash. Switched to the Scorpion 1.5 with recommended lash, no excess noise. No difference in the way it runs that I can feel, less stress on the valve springs too.
any difference when adjusting roller rockers over stock rockers, using self aligning? redfish211 Engine 1 10-12-2011 03:12 PM
Shaft mount rockers VS stud rockers? Stonebrier 2 Engine 2 06-07-2010 05:40 PM
roller rockers and cam VS. standard cam and rockers slipfreak84 Engine 5 09-30-2008 10:55 PM
standard rockers vs. roller tip rockers andybird Engine 6 02-27-2003 12:18 PM
