Many engines benifit from a longer duration cam on the exhaust side. This helps with exhaust scavenging to keep the intake charge as clean as possible. Makes a bit more power...
Chris |
Most people unless the exhaust port is really bad will run the 1.6 rockers on the intake valve. This combination does show some improvement on the dyno. The reason why is where the difference in opinion comes from. Most believe (and I do too)it's due to the increased area under the curve on the intake stroke without the drawbacks of too much duration. On a standard .842 SBC lifter the rate of lift per degree maxes out around .007 using a higher ratio will open the valve quicker without having to go to a larger diameter lifter. Thus making for a seemingly more aggressive cam profile.
BSE Racing Engines |
