1.5 roller rockers - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2013, 10:35 AM
1.5 roller rockers
I have a sbc 406 with 1.5 roller rockers i can adjust the rockers with motor running, without a oil mess is this nomal
Old 03-10-2013, 01:27 PM
Some engines will make more of a mess than others, depending on rpm, oil temp/viscosity/pressure, type of cam/lifters, style of rocker, poly locks, and valvetrain geometry to name a few variables.
The poly locks can deflect/catch oil at lower rpm that might otherwise reach the tip of the rocker if stock type adj. nuts were used, or maybe not? Just a thought. Did you rev it up? Was it hot?
Did you check valve train geometry? Does the pushrod hole come close to the hole/relief in the pushrod seat of the rocker? Can you see oil getting to the trunion?
I've seen some engines not make much of a mess, and others give you a burning hot bath without using deflectors.
If oil is getting to the trunion it should be ok IMHO.
ssmonty
Old 03-10-2013, 02:08 PM
Banned
If you want to do a clean job take a set of scrap valve covers and cut a hole over each rocker stud large enough for your adjuster, put the covers on then adjust your rockers with it running.
Old 03-10-2013, 05:02 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
It will also depend on if the motor has oil restrictors also, this will limit the amount of oil to the top end.
any difference when adjusting roller rockers over stock rockers, using self aligning? redfish211 Engine 1 10-12-2011 04:12 PM
Oil Restrictors with Solid roller cam and roller rockers RippinRon Engine 8 05-16-2010 11:15 AM
Roller Rockers Question - Roller Pin Coming Out leejoy Engine 9 11-27-2008 01:52 AM
roller rockers or roller tip rockers Jared Engine 18 08-01-2007 02:18 PM
standard rockers vs. roller tip rockers andybird Engine 6 02-27-2003 01:18 PM
