-   -   1.5 vs 1.6 on a 406 (http://www.hotrodders.com/forum/1-5-vs-1-6-406-a-137393.html)
sunman 04-21-2008 03:30 PM
1.5 vs 1.6 on a 406
what do U builders think about intake & exhaust ratios?
stay w/1.5's on all 16 or mix'em up w/1.5's Int/1.6 exh. or 1.6's on 16 valves
have a 263 int/273 exh @.50 cam w/13.8:1 c/r 406sbc. TunnelRam in a flat bottom boat, got 1.6 on the heads now, but the builder didnt do a good job of ck'n the 1.60 springs vs. the underside of the rocker, alum in the filter :pain: so I'm gonna get the correct rockers for the springs, so nows the time to decide on ratios and what about useing the old push rods 8.100 on 1.5's? its a no-no :rolleyes:
Holder350 04-21-2008 06:16 PM
just buy a cam that will do all the work...........1.6 is mostly to pep up a stock motor.
engineczar 04-21-2008 07:26 PM
Depends on the application.
What style lifter is the cam ground for. Roller or flat tappet? Also what cylinder head are you using?
ap72 04-21-2008 09:44 PM
Then why do race engines often run ratios in excess of 2:1 on solid roller cams?
