1.5 vs 1.6 on a 406 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2008, 02:30 PM
1.5 vs 1.6 on a 406
what do U builders think about intake & exhaust ratios?
stay w/1.5's on all 16 or mix'em up w/1.5's Int/1.6 exh. or 1.6's on 16 valves
have a 263 int/273 exh @.50 cam w/13.8:1 c/r 406sbc. TunnelRam in a flat bottom boat, got 1.6 on the heads now, but the builder didnt do a good job of ck'n the 1.60 springs vs. the underside of the rocker, alum in the filter so I'm gonna get the correct rockers for the springs, so nows the time to decide on ratios and what about useing the old push rods 8.100 on 1.5's? its a no-no
Old 04-21-2008, 05:16 PM
Holder350's Avatar
Auto Parts Professional
just buy a cam that will do all the work...........1.6 is mostly to pep up a stock motor.
Old 04-21-2008, 06:26 PM
engineczar's Avatar
Depends on the application.
What style lifter is the cam ground for. Roller or flat tappet? Also what cylinder head are you using?
BSE Racing Engines
Old 04-21-2008, 08:44 PM
How fast is fast enough?
Then why do race engines often run ratios in excess of 2:1 on solid roller cams?
1.5 vs 1.6 roller rockers? Streetmaster Engine 10 09-09-2005 10:27 PM
1.6 to 1.5 roller rockers-which should i use 65vettestroker Engine 5 11-07-2004 12:24 AM
1.5 vs 1.6 rocker's bowtieorbust Engine 1 03-13-2004 07:53 PM
1.5 vs. 1.6 ratio rockers Jared Engine 1 03-11-2003 08:12 PM
1.5 and 1.6 rockers chevyelc81 Engine 3 11-06-2002 06:59 PM
