Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1.5mm tip only. What problems
Old 11-30-2005, 05:36 AM
baddbob baddbob is offline
It may spray just fine. What kind of paint will you be spraying? I would just shoot some test panels and try choking down your fluid adjustment some. The 1.5 tip is going to give you more fluid volume than a 1.4 or 1.3. If you're getting orange peel try upping your air pressure and decrease your fluid. What brand and model gun-maybe someone here will have good recomendations for you particular gun. Bob
