Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1.5mm tip only. What problems
Old 11-30-2005, 04:15 PM
kenseth17 kenseth17 is offline
I have a 1.5 in the cheap chinese knockoff gravity feed I bought. I haven't had a chance to really test it out much yet. I did spray clear with it on a bumper and fenders and it seemed to do allright. I did get a slight amount of peel, but not that bad. With more experiementing, maybe it will improve even more. 1.5 falls toward the upper end of a lot of paint manufacturers recommendations I believe though. low air pressure is one cause of peel though. What do you mean by if you increase air pressure you will blow the guitars away? Are you talking about them moving around when you spray them. I you hang them to spray, if you can hang from more spots and wires, it will normally move around less when you spray.
